04-28-2016, 11:04 AM
engine bay fan
I don't seem to recall ever hearing my engine bay fan working, but then again, I might not have realized that it was on maybe whilst I was driving. How can I check if it works, point a heat gun at the sensor perhaps? I checked the fuse and it seems to be ok. Does anyone know when I should be expecting it to go on?
04-28-2016, 11:15 AM
01101
Mine has only ever run on days that are over 90F. Its pretty rare.
04-28-2016, 11:27 AM
There Is No Substitute.
The fan is controlled by the DME, and it has a few triggers for coming on. The most common one is the engine bay temp exceeding 180° F. It should not be running regularly, for me it most commonly comes on on very hot days or in slow traffic.
http://986forum.com/forums/general-discussions/11234-engine-compartment-fan.html
04-28-2016, 11:52 AM
But is there a way to know that the fan does work?
04-28-2016, 11:56 AM
04-28-2016, 12:03 PM
Originally Posted by rick3000
If I jumper the relay, how would I know if the relay is working? Wouldn't it be easier heating up the sensor ?
04-28-2016, 12:35 PM
It would be one Hell of a lot easier to just connect your Durametric and switch it on.............
04-28-2016, 12:41 PM
I would if I had a durametric, but I don't have one unfortunately!
04-28-2016, 04:36 PM
A quick way to check the fan itself is just unplug it from the harness and hook up a +&- to it. It's only a simple fan motor
Woody
05-30-2016, 03:09 PM
You bought a Porsche, but a Durametric!  It will pay for itself in short order.
05-30-2016, 09:24 PM
When you jumper the fan relay, the relay is taken out of the circuit. With the jumper in place, the fan should turn on - if it doesn't, then the fan or wiring is the problem.
Please take a look at the link that Rick posted for details on how to jumper around the relay: http://986forum.com/forums/diy-project-guides/60239-engine-compartment-fan-manual-switch.html
06-03-2016, 09:42 PM
Also try turning the key back to ON after a long drive and turning off the engine. I've heard that fan kick on a couple times I've done that.
06-16-2016, 08:40 PM
Since I live in az and we are scheduled to hit 120 degrees this year, I have though of wiring both radiator fans and my engine fan to either a toggle or to my AEM gauge to trigger it when I hit a certain temp.
