Old 05-09-2014, 09:38 AM   #21
Hello Jeff,
I am sorry when I posted the message it was way past my bead time... LOL
Yes, I WILL be locking the crank at TDC (at the flywheel side of the engine), the question is can I determine TDC by the position of the cams since my underdrive pulley does not have a mark on it.
Sorry for the crummy picture
You can line the cams up using the notches, but be aware they are not symmetrical (centered):
Old 05-09-2014, 09:44 AM   #22
Registered Boxster abuser
healthservices's Avatar
If both cam locking tools will not slide in completely it is not at tdc. hopefully you still have your old crankshaft pulley, it can't be more than 15 mins of work to slip that back on. Otherwise how are you locking the crank at TDC?
Old 05-09-2014, 12:01 PM   #23
HS,
1) The cam locking tool I was able to borrow does not have the tabs that slide into the cam notches, it has two bolts that press against the cams to keep them from rotating (by friction)
2) I was planning to lock the crank at the rear (flywheel side) using a steel bar between the crank bolts and the bellhousing
3) Unfortunately, when I installed the underdrive pulley, I used plenty of locktite red (yes, shame on me...) and I don't have a big enough breaker bar that will be required to loose the crank bolt, however, I do have the OEM pulley
By any chance do you have the locking tool that locks the cams by inserting the wedges into the cam slots? I live in Yorba Linda and I am very close to Tustin...
PLMK
949-382-6130 (work)
714-393-4173 cell
PS, if you want to come over, I will make a BBQ with plenty of Shock Top and Tequila... LOL
Old 05-09-2014, 01:36 PM   #24
Jeff,
Thank you much for the picture, I will ensure that the cams are aligned the same way as the picture, 2-6 bank center picture (Cayman driver side) and the 1-3 bank right picture (passenger side)
NOTE: The Smaller 1/2 moons are facing towards the outside of the engine, right?
Once I align the cams I will lock the crank, then the cams and I can move on and remove the chain tensioners and lastly the IMS cover..
Getting there... Thank you for the support!
