Old 04-21-2017, 08:37 PM   #14
Originally Posted by Stroked & Blown View Post
The ROW flash is looking like a much better option. Cheaper, simpler, and adds lightness.
There is a far more compelling case than that for some of us. We can not fix the SAI system. Some very competent Forum members have performed every imaginable test yet fail to find a fault. If you can't find the fault, you can't eliminate the SAI fault codes .If the SAI fault code is present, you can't pass the Smog test so you can't get a registration sticker. If you run out of time on your old sticker you are in real trouble.
Ultimately there is no alternative to the ROW flash until someone figures out a reliable way to fix the SAI system.
Sometimes it is easy to fix the SAI but not always !
