Old 02-16-2014, 07:54 AM   #1
Head Gasket Sealant
Has anybody used or know if you can use a head gasket sealant on the boxster. I have the tell tale sign of white smoke and disappearing coolant. Would a sealant be ok for a temporary fix whilst I save up for the replacement gasket or will it do a greater damage? I'm gutted as I've just replaced all of the coil overs and she was running perfect again.
Any info would be appreciated
Adz_Boxster is offline   Reply With Quote
Old 02-16-2014, 08:38 AM   #2
I've found K Seal which promises to answer all my problems, has anybody tried this ?
Old 02-16-2014, 08:56 AM   #3
In all the years I have worked on these cars, I have never seen (or heard) one blow a head gasket. And the OEM head gaskets need no sealant of any kind.
Old 02-16-2014, 09:20 AM   #4
Would there be another reason the coolant is leaking into the engine and causing it to smoke white other then a cracked cylinder ?
Old 02-16-2014, 09:34 AM   #5
Most common failure are cracked cylinder heads, followed by cracked cylinders:
Old 02-16-2014, 10:20 AM   #6
Engine Surgeon
These engines use MLS head gaskets. Don't even consider using a sealant. If you have intermix, it's not a blown head gasket- the gaskets are stronger than M96 heads. We've never ever seen a head gasket fail on these engines.
You have a cracked head or cylinder. You may beat your head against the wall trying to figure it out and waste a lot of time.
US Patent 8,992,089 &
US Patent 9,416,697
Old 02-16-2014, 04:06 PM   #7
jsceash's Avatar
Your not going to feel any better after this either. Check your compression do a leak down test or have your local mechanic and expect the worst.
MY history is
Old 02-16-2014, 04:25 PM   #8
Engine Surgeon
WOW! Someone tried to hone that cylinder!!! Guess they never heard of Lokasil before! Must have thought they were working on a Chevy 350!
US Patent 9,416,697
