Old 07-30-2013, 04:32 PM   #1
Horn Problem
Ok. Today I was driving home from work in my 1999 base model and every time I down shifted into second gear the horn started blowing! It also blew when I hit a serious bump in the road. I have read other threads about the horn blowing when the brake was applied, but this seems to happen every time I down shift to second gear. Do you think it's the bracket behind the airbag that needs replacing?
springer123 is offline   Reply With Quote
Old 07-30-2013, 06:24 PM   #2
DER BXTR - Basalt Black
q2usmc's Avatar
Yeah, it's the worn out bushings on the bracket that's causing your horn to go off when downshifting. Eventually it'll start happening more frequently such as every time you start to brake. Use the search function on here to find how to fix it- some people replace the whole bracket while others just "tweak" the bushings or make new ones.
q2usmc is offline   Reply With Quote
Old 07-30-2013, 07:52 PM   #3
Johnny Danger's Avatar
Try laying off the Viagra for a few days.
