05-15-2013, 01:56 PM
CEL after oil change & inspection
Had oil changed and NYState inspection. Two stops on the way home, car drives fine but before I turned the engine off in the garage I noticed the CEL? Anybuddy else have this kind of sequential event? Light is on but car runs well not badly and light is not pulsating. I checked to insure the gas cap was tight ( it is) and the oil cap is turned down tight. Any suggestions?
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
05-15-2013, 02:35 PM
Get the error codes read, then someone can make a suggestion/guess as to what is happening.
05-16-2013, 01:16 PM
Got my code readings
Finally got my Durametric hooked up and it shows Porsche code 80 - Secondary air injection & P code 208 Secondary air injection. Vacuum hose, solenoid or ?
Also my cam deviation (while I was at it) is -6.93 & - 3.65, anything to worry about here?
AKL
