03-23-2013, 10:31 AM
water pump level at min but drips
so I topped off my water pump and it drips after drive but only to the min. than seems to hold there. changed out updated cap.
should I replace the entire pump?
thks in advance.
03-23-2013, 10:42 AM
It's not clear what is dripping. Is it the tank in the trunk or the water pump in front of the engine. Either way, you should change our whatever part is leaking.
03-23-2013, 10:44 AM
thks in advance.
If you are saying your water pump is leaking coolant, YES replace it immediately, this is the best way to find out your pump is failing.
03-23-2013, 10:49 AM
honestly not sure. coolant level doesn't drop below min. and I get a leak infront of rear wheel.
03-23-2013, 10:50 AM
I'm hoping its my coolant tank. cheaper or sho
03-23-2013, 11:02 AM
also temps never go past the 8 /0 mark
03-23-2013, 01:30 PM
thks in advance.
If the pump is dripping, it is only a matter of time until it fails and strands you or kills your engine. Replace it.
03-23-2013, 02:14 PM
Pull the carpet in the trunk and look for stains... Water pump leaks at the front of the engine. Coolent tank leaks into the trunk, or in front pax side rear wheel. Could be a bad cap...
03-23-2013, 04:40 PM
Leaving aside that the coolant tank is actually more expensive than the water pump, anyone who says he would rather change a coolant tank than a water pump has obviously never tried to change a coolant tank in one of these cars!
'99 black 986
03-23-2013, 05:29 PM
yr right mark: no clue: I will take all advice tomm and update tomm. I did replace the cap. if it's the water pump than why does coolant level holds at the min mark? I will pull carpet and check. thks for replies
03-23-2013, 06:58 PM
If the coolant level drops to the minimum and NEVER goes below it, then the tank is the most likely source of the leak and the crack is at the minimum level.
03-23-2013, 08:10 PM
Tom, that's what I'm thinking: ill check trunk carpet in morning : thks for thoughts
03-23-2013, 09:09 PM
If it's the coolant tank, this should help:
Replace Coolant Reservoir
The job is a real bear. Have some good hose pics, and the cable operated clamp tool is well worth the money.
'99 black 986
03-30-2013, 11:46 AM
sorry for delayed response. finally got time to pull the carpet back. pools of coolant and wet carpet in the trunk. just as you guys suspected. atleast now i know the problem.  thanks so much. now just have to decide if i can do it myself or pay to get it done
03-30-2013, 11:55 AM
still odd though that it does not drain , coolant level stays at minimum level?
03-30-2013, 12:47 PM
03-30-2013, 12:54 PM
update. i turned on the car and let the temp go to 180 and watched coolant level in reservoir go up. still no leak i saw. i replaced with updated cap already.
03-30-2013, 02:31 PM
Had a similar problem with my car the first time it went on track, it was the tank leaking down to the wheelwell. And it only leaked when it was hot, tank expanded some and exposed the crack which I could never see until it was out of the car. Plan on an entire afternoon to change it out. Was not fun.
03-30-2013, 03:02 PM
You need a new tank, period.
03-30-2013, 09:26 PM
yes your prob right Jeff.
i pulled carpet and took a 45 min drive. not a drip. ! im thinking i overfilled it? but its at minimum. when i topped it off it seemed to expand . but after a good drive, not a drip. i have a feeling if i top off the coolant, it ll leak again.
