Old 02-10-2013, 03:27 PM   #1
what is this transmission screw?
Hello, do you know what is this transmission screw?? I've got an oil leak.
heiwaz is offline   Reply With Quote
Old 02-11-2013, 11:40 AM   #2
nobody knows?
Old 02-11-2013, 07:54 PM   #3
Moderator
It may just be a regular screw that holds the transmission. It's certainly not the transmission drain plug or where you fill the fluid in the transmission. When you say you have an oil leak, is it engine oil? That could indicate a leaking RMS or loose oil drain plug.
Old 02-12-2013, 01:52 AM   #4
Spinnaker's Avatar
Possibly #2?
Porsche Boxster Transmission Single Parts Parts
