Old 01-25-2013, 09:32 AM   #1
Flakes of aluminum found in oil filter.
Keep finding non-ferrous flakes of aluminum in my filter. They are soft and have the consistency of tin foil. I am wondering where they are coming from. I tend to find 2-3 per oil change and they are roughly .8-1.0 mm in size. Checked IMS bearing 3 months ago it looked and sounded fine.
desertsoldier22 is offline   Reply With Quote
Old 01-25-2013, 10:20 AM   #2
Sounds like its perfectly normal. Even years after the car is put into service, left over junk from the machining of the motor at the factory will show up. One or two small bits is nothing to worry about. It can't be the IMSB since it has no aluminum. Just keep monitoring your filter.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-25-2013, 10:30 AM   #3
BYprodriver's Avatar
You should get a oil sample analyzed & remove the sump plate to look around & clean the oil pickup & install LN magnetic drain plug. How many miles on your engine?
Nothing to lose sleep over just a opportunity to improve your car.
Old 01-26-2013, 10:52 AM   #4
64,000miles on the car...it is 3.2l
Old 01-26-2013, 11:01 AM   #5
You should be in good shape. Search the forum for good oil recommendation when you have alot of time.
Old 01-26-2013, 06:35 PM   #6
Been using a 5w-40 mostly because of the winter cold when I went to Michigan, putting 15w-40 back in after my IMS bearing retrofit install next month. The heavier weight oil quiets down the valvetrain noise I hear. I have heard that the valvetrain noise can be eliminated by replacing a spring and plunger in the cars oil pressure regulator, it seems simple enough to do.
Old 01-27-2013, 05:00 AM   #7
Replacing the oil pump spring will not compensate up for noise caused by worn chain guides, weak tensioners, low film strength oils, or bad lifters..............
