Old 01-12-2013, 11:52 AM   #21
02 box s
See if the rear O2 sensors are long enough to work in the front, they should. If so you may want to get new rears & install in the front. You may get a CEL for slow heating of the O2's so keep in mind to minimize that.
Thanks pro. I usually do my own work but things are so hectic with work lately that I just have to pay someone else at this point. If the rear o2 sensors are longer then that seems like an easy fix. What's the worry over the heater? Would I be better served to try something different? My mechanic was able to make it work with the 90 degree max speed mini cat so the distance is probably about 2".
sgt brad is offline   Reply With Quote
