Old 08-31-2012, 11:18 AM   #14
Originally Posted by Cater View Post
The smoke is only going to be there on start up if it's the oil separator.
My brother has had this happen with his car and It is a very common problem with Boxsters.
This is not true. The nature of any flat engine is for small amounts of oil to pool in the cylinders at shut down. The only reason it does not happen all of the time is because engine tolerances, lubricants and lubrication systems have improved a great deal over the yeasr. Oil can also leak back through the valve guides depending on wear. To say that smoke on start up is an AOS only issue absolutely false...
shadrach74 is offline   Reply With Quote
