Old 08-30-2012, 04:10 PM   #12
Mark_T
Originally Posted by Cater View Post
Smoke on start up is a pretty regular problem on Boxsters, it's the oil separator more times then not.
Sorry, but that's not correct. If the AOS is gone then there are billows of white smoke and it is continuous, not just at start-up. This is just a little blue smoke at start-up and is probably nothing to worry about, unlike the AOS which, if gone, should definitely be worried about.
If there is a concern about the AOS then do the oil filler cap test to confirm or eliminate it as a suspect.
'99 black 986
