08-09-2012, 04:29 PM
Headlights
I just bought a set of 996 headlights and they have the highbeam and the low beam but what is the other small bulb it has been cut out. Also my fog lights do not work now, is there more I should check instead of the bulb, they are out on both sides.
08-09-2012, 05:18 PM
Are you upgrading to Litronics?
08-10-2012, 04:48 AM
Headlights
No I just upgraded to clear lights with the amber removed, but when I opened the back, you can see the high and low beam, but the little lite has had the wires snipped and removed, I was wondering what it was, and should there be a problem with the fog lights going from a 996 to a Box.
08-10-2012, 05:41 AM
My litronics have a little daytime running light, that could be what the wires were cut from
08-10-2012, 06:52 AM
does the light look like this:
or like this:
08-10-2012, 07:21 AM
Headlight
The lower one, but I couldn't find any pictures of the back exposed showing what the little bulb is for, and with it gone would it make the fog light not work also?
08-10-2012, 09:01 AM
which one appears to be cut / missing?
back, inside panel (low beam on top, high beam on bottom):
fog light:
turn signal:
08-10-2012, 12:23 PM
Headlights
In the top picture, I see the hig and low beam, what is the little light next to them, mine only has a hole, and the wires have been clipped.
08-10-2012, 12:27 PM
Opposed to Subie Burble
Travis, do you mean this?
-O/D
IMSR + RMS
Robbins glass window top
08-10-2012, 03:46 PM
headlight
Yes, mine has been removed and the wires cut.
08-11-2012, 09:31 AM
Those are parking lights.. bulb number 194 or 168
2K Boxster White/Grey Int./Hardtop/TIP
08-11-2012, 10:58 AM
I was curious about that too. Was it an option? It seems not all cars have them.
'99 black 986
