Old 07-10-2012, 02:23 PM   #1
Andrew McD's Avatar
Window rattles when shutting the door?
Hi,
My drivers side window rattles when down and you close the door. Sounding very cheap. Anybody have any ideas?
Thanks, Andrew.
Twitter if anyone is interested... @JAZ5788_Boxster
Boxster 2.7 with a few mods: RSS Under drive pulley, Dansk OEM look polished stainless steel sports silencer, K&N air filter, Full new M030 Sports Suspension, 997 Gear selector, and a load of other OEM styling upgrades.
Andrew McD is offline   Reply With Quote
Old 07-10-2012, 04:20 PM   #2
bar10dah's Avatar
I'm sure you've already thought of this: Take the door panel off and see if you can spot anything not connected right. Maybe some attachment in there is loose or has fallen off?
bar10dah is offline   Reply With Quote
Old 07-10-2012, 08:50 PM   #3
My passenger side does it. i took off the panel but didn't see anything obvious. My work-around is to raise the window ever so slightly and that stops it.
'99 black 986
Old 07-11-2012, 03:58 AM   #4
Andrew McD's Avatar
I'll have the door panel off at the weekend so will have a hunt then. :-)
Old 07-11-2012, 07:02 PM   #5
bar10dah's Avatar
Is the inner or outer felt missing from the top of the door?
Old 07-11-2012, 07:03 PM   #6
bar10dah's Avatar
Could be a waste of time. But, might as well give it a shot.
Old 07-14-2012, 08:19 AM   #7
Andrew McD's Avatar
Well had a look today, it looks like the window stop is in the wrong position. As in the bottom of the two positions. Anybody know how you move it to the upper one? As it looks to be riveted in place. Also I fitted new silver door handles, but my new ones seem to have little lights in them. Is there a loom section that connects them to the puddle lights?
Old 07-14-2012, 09:25 AM   #8
Mine does this both sides. Be interested to hear how easy it is to sort. Not convinced I can be arsed to take the door cards off, however!
pothole is offline   Reply With Quote
Old 07-16-2012, 01:28 AM   #9
Andrew McD's Avatar
Taking the door cards off was easy. ;-)
