Old 05-01-2012, 03:25 PM   #1
Couper1's Avatar
Help-Strut disassembly question
Hi Guys,
I removed my strut and installed the spring compression tool, and then removed the nut at the top of the strut.
Now, how does the rest of it come apart so i can remove my spring??
It almost seems to be frozen on there
Couper1
Couper1 is offline   Reply With Quote
Old 05-01-2012, 03:31 PM   #2
Is it front or back?
Once the top nut is removed the plate should come off and then the entire spring can be taken out. Did you compress the spring with the tool? If not do a little bit. then tap the top plate out slowly. Make sure the tool is seated well.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 05-01-2012, 03:40 PM   #3
Couper1's Avatar
Really? with the nut removed that whole triangular plate should come right off? yes i have the spring compressed, and i did try tapping it but it looks like is on there solid.
I will spray a little WD-40 in the there and try tapping again.
Thanks!
Old 05-01-2012, 04:17 PM   #4
Couper1's Avatar
That thing isn't coming off.
Old 05-01-2012, 04:18 PM   #5
Couper1's Avatar
That thing isn't coming off. it's the front strut by the way.
Old 05-01-2012, 04:28 PM   #6
bar10dah's Avatar
Can you try loosening the spring compressors (just a very little bit at a time!) to see if that'll help move the plate along?
bar10dah is offline   Reply With Quote
Old 05-01-2012, 04:37 PM   #7
Couper1's Avatar
Ahh, excellent idea bar10dah, thank you I will give that a try.
Old 05-01-2012, 05:08 PM   #8
Couper1's Avatar
Got it off. with the spring depressor tool on and tight I picked up the whole assembly and gave two good whacks with a hammer one the end of the strut where the nut was removed from, and that sucker popped right out.
Thanks for your replies and help gentlemen.
