Old 03-04-2012, 06:44 AM   #1
LAP1DOUG's Avatar
Anyone else running a lean coolant mix?
I had always heard that ethylene glycol has a poor specific heat compared to water. Recently, I found this source confirming the reduced heat capacity of glycol solutions:
http://http://www.engineeringtoolbox.com/ethylene-glycol-d_146.html
So, when I flushed my system out recently after changing to a low temp. thermostat, I mixed up my brew with only 25% Porsche OEM glycol + 12 oz. Red Line Water Wetter + Water.
My test on this mixture indicate a freeze point of about 7F, which should be more than adequate for garage storage in Georgia, and a 14 psig pressure boil point of 258 F, which is only sacrificing about 4 F from the 50% solution pressure boiling point.
I searched on here, but did not find where anyone else was doing this. As I recall, most racing rules require 100% water for ease of track clean-up, but where there are no sanctioning rules to meet, I believe a lean mix is the way to go if your cold weather and storage conditions will allow it.
Kippis
986S
991S
Van Diemen RF97
