Old 12-31-2011, 09:00 PM   #21
When you say bearing marks... are they scratched into the input shaft or just grease marks? No the starter should not be engaged.
Stick a pencil in the pilot bearing hole, mark it and compare it to the tip of the input shaft length.
Usually the trans will go right on if everything is lined up, also that starter might be an issue.
feelyx is offline   Reply With Quote
