Old 09-17-2011, 12:55 PM   #1
Sudden Power loss
Hello
I have recently done the EvomSit solution ( ECU flash and installation of Air Flow Intake ) and when I do a hard acceleration ( 5 to 6 rpm) I loose all the power of the car ...RPM will be at ! or 2...the only way to recover from this situation is to re start the engine and everything is back to normal.
My dealer says that it is the Mass Air Flow Sensor however there is no faulty code.
Before I spend another 500 $ I would appreciate some comments
Many thanks
cyben is offline   Reply With Quote
Old 09-17-2011, 02:21 PM   #2
Always go back to the last thing you touched: Undo the ECU reflash back to stock and see what happens. If it still does it, look at the intake system you installed.
Process of elimination.............
Old 09-17-2011, 02:45 PM   #3
DenverSteve's Avatar
Too little information. Was all the work done at the same time by the same mechanic? Did the problem (losing power) start immediately or after a while? Did the mechanic test the system/car after doing the work and before returning it to you? Have you spoken to the mechanic about the problem so he could evaluate the situation.
Both of your changes have electrical (computer) implications associated with them so, as stated above, you'll have to eliminate one at a time and see which one is causing the problem. I would take back to the shop that did the work and have them make it right.
Denver Steve
DenverSteve is offline   Reply With Quote
Old 09-17-2011, 03:18 PM   #4
Yes the same mechanic did the job and tested the car ...car was ok
This happened a few days latet and it is intermittent
So I my have to re flash teh ECU at its original state.
Old 09-17-2011, 03:42 PM   #5
That's where I would start. I would have the mechanic do it as it was their work that caused the situation. Good luck with it. It's never fun to have a niggling, unresolved problem.
Denver Steve
Old 09-17-2011, 04:20 PM   #6
Thank you for your good advice
I hope they eventually find it
