Old 09-09-2011, 05:12 AM   #3
I've read some "no start" threads like yours and sometimes the fix is a new fuel pump. There is a test port at the motor to hook up a gauge to check the pressure. Also sometimes Porsche mechanics have a special test relay to verify that the pump is getting the voltage needed.
It's only guessing when somebody like me says they know the problem after reading about the symptoms but when the motor cranks with no start the fuel pump is definitely a possibility.
Dale_K is offline   Reply With Quote
