Old 09-10-2010, 11:00 AM   #1
Correct Motor Mounts for 3.4L Swap
trying to make sure i order the right things. need to lower the motor / transmission for the 3.4L swap.
wayne at pelican gives 993.375.049.05 as the proper mount. renntech tells me this is superceded by 993.375.049.09.
can anyone verify this will work? thanks
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 09-10-2010, 01:27 PM   #2
I had thought you used 964 mounts, not 993 mounts (though they may be the same?)? For the cost of the mounts (probably $200-300 each times 2) you might consider just getting the X51 intake and leaving the motor at stock height.
Boxster S
Old 09-10-2010, 03:29 PM   #3
i thought 964, too. wayne lists a previous 993 number on his site from his 3.4 conversion. i found that part, new, for $117ea.
no idea where to source an x51 intake other than a dealer. list is $364.....per half. i'm guessing i could get one from Sunset for around $550. i'll cut & weld my old mounts before i pay that much.....
insite
'99 Boxster
3.4L Conversion
Old 09-10-2010, 03:36 PM   #4
That's not too bad....when I looked up the 964 mounts they were over $200/ each wholesale.
Boxster S
Old 09-10-2010, 03:40 PM   #5
apparently there's an aftermarket supplier now (corteco). just found them at pelican even cheaper; $104 each.
insite
'99 Boxster
3.4L Conversion
Old 09-10-2010, 04:16 PM   #6
JAAY's Avatar
Hold the phone! I picked mine up for 50 bux for the pair. Used but in better shape than my stockers. For that price if they go bad you can still get another 3 sets and be ahead of the game. That's my thoughts.
JAAY is offline   Reply With Quote
