08-14-2010, 02:47 PM
Creamy light brown/tan gunk in coolant tank
Thought I found a great deal on an 01 S until I looked in the coolant tank. Coolant level dropped to the bottom of the tank on my 4 hour drive home with car and the top of the pinkish coolant has a tan/light brown layer of creamy stuff on it. Any idea what the problem might be?
08-14-2010, 02:55 PM
a number of things....oil cooler,casting "freeze plug". is it alot of stuff in the tank? hows the oil color/level ?
08-14-2010, 02:56 PM
Oil color and level is right on.
08-14-2010, 03:00 PM
There is a layer of the gunk about 1/4" thick on top of the coolant.
08-14-2010, 03:07 PM
07 Carrera S Cab
Here, take a look at this thread: http://986forum.com/forums/showthread.php?t=24696&highlight=Oil+coolant
Hopefully, it's just a bad heat exchanger/Oil cooler, and not a cracked head.
08-14-2010, 03:10 PM
You have an intermix problem; common causes are a failing oil cooler (common), a popped freeze plug (also common), blown head gasket (less common), or a cracked head (also less common).
You need to stop using the car immedeately. It needs to be checked by someone that knows what they are doing. If it has to be moved to get it to them, flatbed it, DO NOT DRIVE IT.
Anything really new is invented only in ones youth. Later, one becomes more experienced, more famous and more stupid. - Albert Einstein
08-14-2010, 03:53 PM
Thanks for the input everyone. Are any of these potential fixes something I may be able to check out myself (limited skills) or does anyone know of somebody in the Madison area (WI) I may be able to get it to for help? I have limited funds and don't think a dealer will work for me.
08-14-2010, 04:56 PM
07 Carrera S Cab
I would first try to return your car to whomever sold it to you for a refund!  If that doesnt work, you could try to contact your local PCA chapter to see if they could recommend any local independent Porsche repair shops: http://vista.pca.org/cwi/
08-14-2010, 07:01 PM
If there is oil in the coolant would it appear the usual color of oil? This stuff is very light in color - like a light pair of khaki pants.
08-14-2010, 09:52 PM
Porscheectomy
It's oil, not much doubt.
08-15-2010, 02:25 AM
07 Carrera S Cab
The oil is mixed with a lot of coolant (the coolant tank you see is only the coolant overflow tank, so it shows only a small fraction of the overall coolant in the system), so the oil in the tank you see will not be all black like oil itself. Instead, it would look like what you're looking at now...a frothy tan colored milkshake-like mix. Hate to say it, but it's almost certainly an oil/coolant intermix, and you can't keep driving the car without addressing it because you will really damage the engine.
If you can't afford to fix the car at a dealer or independent shop right now, buy a Bentley Repair manual and you can perhaps try to replace the oil cooler/heat exchanger yourself to see if that was the cause of your intermix. Of course, you'll also have to flush and refill/burp your coolant system tank as well. If that doesn't do it, you'll really need to take it to shop that knows Porsches.
Repair manual:
http://www.amazon.com/gp/aw/d.html/ref=redir_mdp_mobile/185-9993856-2479431?redirect=true&tag=porschepetesboxs&a=0837613337
08-15-2010, 08:48 AM
UPDATE: Found a guy a few miles away that has done work on boxsters. Car ran fine on the trip there at speeds up to 75. Car temp was good and no funny smells when I got there. First thing noticed was one radiator hose was warm and one was not. Also, fan was not blowing warm air from radiator. He thinks I should just replace thermostat to start. Does this sound right to everyone? Thanks again for all the help.
New problem. Got the car home and smoke (not a lot) was coming out of the vent by passenger side door. Any thoughts?
08-15-2010, 09:09 AM
07 Carrera S Cab
Lol. How is changing the thermostat going to fix the oil intermix problem you have in your coolant tank? Smoke coming out of your engine vent could mean some loose connections that lead to your coolant tank, among other things.
Two people on this board (one, a repair shop owner), have recommended you not drive the car anymore until you fix the oil intermix problem, but you ignore it and drive your car up to 75mph anyway. Lol. I think you should now drive it up to 100mph just for fun!
08-15-2010, 09:16 AM
I did just get the name of a good local independent Porsche repair shop, I will get it there.
08-15-2010, 09:31 AM
Take the scenic route!
08-15-2010, 09:46 AM
07 Carrera S Cab
Now that's funny!
08-15-2010, 10:35 AM
Yeah, you have a major league issue and yet are not paying attention............if you think your funds are limited now, just keep driving it
08-15-2010, 07:16 PM
Find a shop who knows what they are doing, and DO NOT drive the car until you get this solved (unless, of course, you'd like to buy a new motor).
Boxster S
08-17-2010, 08:22 AM
Hmmm, how can I convert my limited funds to depleted...
08-17-2010, 10:00 PM
I'll second that...
Boxster S
