Old 01-16-2010, 04:44 PM   #1
dallison's Avatar
cracked coil pack
I am changing out the plugs and tube 0-rings 57k and as i am cleaning parts i notice that the coil packs have some small cracks in them. I haven't had any issues with codes or lack of performance.
I am planning on reinstalling them and running the car in the spring. would it be safe to say that i will be needing to replace these at some point? Luckily these are nowhere as expensive as the ones for my old ass es300.
dallison is offline   Reply With Quote
Old 01-16-2010, 04:57 PM   #2
Lil bastard's Avatar
You will eventually be replacing them.
Question is, do you want to pick the time and place, or have the angry Porsche Gods do it to you?
At the very least I would have them on hand. But if the car fails some distance from your home, the tow alone could exceed the cost of replacement, which of course you'd still have to do as well.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 01-16-2010, 05:28 PM   #3
dallison's Avatar
that's what i was thinking. i am sure at some point i'll need to replace them. $250 for all 6 isn't too bad.
Old 01-16-2010, 05:35 PM   #4
I dove around for over a year with cracked coil packs. I was told that you only really have to worry about them if they get wet. I don't know how sound that advice was. I figured that it was an easy fix so I just replaced them all.
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 01-17-2010, 11:12 AM   #5
You'll wind up swapping em sooner or later. If you can guarantee the car won't get wet, I suppose you could put it off until later, but were it me, I'd just replace all of them and have some peace of mind.
Boxster S
Old 01-17-2010, 02:30 PM   #6
dallison's Avatar
the car isn't driven in the rain and i don't really get the motor wet, but i may do it next winter.
Old 01-17-2010, 02:59 PM   #7
Engine Surgeon
After 30K the OE coil packs will generally have a couple of cracks.. Generally these do not effect their performance.
When I perform a 60K service I replace all the coil packs, cracked or not
US Patent 8,992,089 &
US Patent 9,416,697
Old 01-18-2010, 04:40 PM   #8
dallison's Avatar
i will keep that in mind. Is there special lube that i need to use to grease the o-rings on the spark plug tubes?
Old 01-18-2010, 09:02 PM   #9
I think I used a dab of engine oil on each ring. Worked like a champ.
gschotland is offline   Reply With Quote
Old 01-19-2010, 06:34 AM   #10
ppbon's Avatar
The real enemy of the coil packs is...
... water.
If you see any minor cracks, it's usually just in the plastic case.
What I do is put a bit of epoxy resin in the cracks to seal them up.
Mine are still OEMs with almost 200K miles on them and a bit of epoxy every now and again.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 01-19-2010, 10:18 AM   #11
dallison's Avatar
sweet, i was hoping to use something i have in the garage.thanks
Old 01-22-2010, 06:58 AM   #12
dallison's Avatar
pedro, that transom works wonders when pulling out the plug tubes
