Old 10-11-2009, 06:50 AM   #3
reply to jjanari
Originally Posted by jjanari
I had something similar and it turned out to be a failing clutch switch. however, since you mention putting it in "park" and "neutral," I assume you have a tip??
otherwise, strange electrical can sometimes be a failing ignition switch. have you ever replaced yours?
are you sure the battery is ok (I know you said it "checked out," but I'm not sure how you tested it).
Thanks for response.
Yes car is tiptronic.
Checked battery with voltmeter then connected charger and full charge led indicator lights up on charger
thanks
kelidan is offline   Reply With Quote
