			Gary,
 Yes. Simply disconnect the battery (all you need to do is remove the negative side). You will  need a Torx driver to remove the two bolts on the back of the steering wheel (T-25 I think). The thread lock on those bolts is pretty strong. The air bag will come loose, there is a small plug connector on the back of the airbag, disconnect that connection and the airbag should be free.
				__________________kabel
 Orlando - 99 BMW  M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
