Old 01-31-2009, 12:50 PM   #1
JAAY's Avatar
Where to Buy.....
So most of you know I just received my 3.4 and I need to do the upgraded clutch. Does anyone know where to get the sachs upgraded clutch for a 2.5? I looked at many websites and no one lists it. Also I will be selling my stock clutch which I just did about 400 miles ago. If anyone is interested in that let me know. Send me a private message. I am open to any offers on that.
Thanks in advance.
JAAY is offline   Reply With Quote
Old 01-31-2009, 03:45 PM   #2
If you want an upgraded clutch just use the 5 speed 987 parts. This will give you enough clamping force for the 3.4.
-Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
Old 01-31-2009, 06:29 PM   #3
JAAY's Avatar
If you didn't know already....... You are the man....
Old 02-01-2009, 10:44 PM   #4
clutch
-Todd
Will this fit a 2000 Boxster S flywheel? Do the 5 speed 987 clutch parts have more torque capacity than a stock 3.2L clutch? My car will need a clutch pretty soon - the pedal is heavy and the engagement point is kinda high - and I really don't want to buy a new $900 flywheel.
Blue-S
2000 Boxster S 6-speed - Ocean Blue / Savanna Beige
* 9x7 short shifter * Pedro's enthusiast mount * Carrera Ltw. wheels * Stebro bypass pipes
* M030 coming soon! *
Blue-S is offline   Reply With Quote
Old 02-10-2009, 01:00 PM   #5
would the 987 S clutch work for the 6spd then ?
thanks ahead of time
nefarious986 is offline   Reply With Quote
Old 02-10-2009, 01:54 PM   #6
No personal experience with this, but the 987 6 speed and 986 6 speed share the same flywheel and other parts so I'm pretty sure the 987 6 speed parts will work on the 986. The 986 6 speed and the 996 use the same pressure plate, so there is the potential to mix and match items from the 996/997 to get more clamping force to deal with higher outputs as well.
The only real limitation is in the Boxster/Cayman model range, 5 speed and 6 speed clutch components (outside of the flywheel) cannot be interchanged.
-Todd
Current Cars:
1989 911 Targa
1971 911T
Old 02-18-2009, 09:30 PM   #7
Send a message via AIM to Christeon
-Todd
I learned that one the hard way myself, I'm still running my 5 speed.
Christeon is offline   Reply With Quote
