Old 01-25-2005, 06:50 AM   #21
Insite
Thanks for the suggestion and quick response.
spgribben007 is offline   Reply With Quote
Old 01-25-2005, 08:26 AM   #22
I would never question your math...Insite
But I would disagree about the ultimate gains acheivable. The current model has 240hp and I believe 197 tq. They did not change the internals of the engine, including cams. They did enlarge the throttle body, add factory manifold (header style) and ecu changes, as well as intake manifold changes (how much I do not know since my 04 has the flapper style intake as well). I believe it is made of plastic now which may help the intake temp a bit.
All relatively subtle changes for 240 h.p.. Is this the last evolution of this motor power wise (no way). But remember Porsche does not want to spend a fortune on exclusive parts and tuning for just this mill and they have noise regulations and blah, blah you know to deal with. Can you make it smog legal sure. The headers will delete the pre-cat but if you use dual o2 cats that are at least 200 cell and get the ecu tuned properly a/f ratio. You should be fine. The pre-cats are for some tailpipe bag test only (not sure what that's about). Ultimately the sniff test on the dyno tells the tale.
I also think unichip is pretty reliable so there dyno numbers along with the cold air intake from scargo should be very close. Of course we all know about the power range of these motors from the factory right (they differ) some are stronger than others. Perhaps the best combo is Intake, Headers, ECU.
P.S. I think this is a great topic and Boxster tuning is just getting it's feet wet. I hope we can someday get a reliable supercharger kit or a less expensive turbo kit 24k is ridiculous. Don't get me wrong the Boxster is a great car but I noticed recently how the power really flattens out past 6k and we have 7200 to work with
04 Boxster 2.7
Fletcher is offline   Reply With Quote
Old 01-25-2005, 12:02 PM   #23
Pilot2519j's Avatar
Exhaust mods
I doubt very much the claim of 20 hp plus. Neil from Orton Motors who specializes in doing performance mods for 986's mentioned that changing the headers from the more restrictive factory model will result in a freer reving engine. He did not mention anything regarding hp additional for doing the mod.
He does do the engine swaps which new engine costs are prohibitive. 16K for the 3.4L and 18K for the 3.8L
Pilot2519j is offline   Reply With Quote
Old 01-25-2005, 03:17 PM   #24
Fletcher -
good points. i think that in addition to the changes that you mentioned, the majority of the gains in the 987 have to do with RPM and nothing more. i think some revisions to the intake have allowed them to maintain good driveability in the low rev ranges while further expanding the top end's spark map / fuel map / variocam program to move the torqe peak further up the ladder.
if you look at the dyno curve on the previous page, all it would take is moving / extending the flat part of the torqe curve (190 lb-ft in that graph, blue curve) from 6000 RPM (peak HP of 217) to 6630 RPM and you now have 240HP. if you go to porsche's website, you will see that indeed, peak power now occurs at 6400 RPM. this isn't the full 6630 that we needed, so they have added 7 lb-ft of torque; easily realized with the larger throttle body and new headers.
i have LONG believed that they drastically underrate the rev limit capabilities of their cars. think about this: my 1986 toyota celica was a 2L 4-cylinder. it redlined at 6900 RPM. It did this with cylinders and valves that were LARGER than the boxster's (2.0L / 4-cyl = .5L / cyl vs. 2.7L / 6-cyl = .45L / cyl) and connecting rods that were longer. from a force perspective, the new box generates 33.33 ft-lb of torque per cylinder; the celica generated 31.25.
considering the fact that a) the inertial mass of the reciprocating parts weighed more and b) this was a massed produced TOYOTA and c) that was 1986; one gets to wondering why that would be.
insite
'99 Boxster
3.4L Conversion
Old 01-25-2005, 04:40 PM   #25
True
I have heard that Porsche is trying to milk these engines in small incriments due to the logical ceiling with the 997's 3.8L mill. They will spread out the h.p. and displacement to allow small steps just as with the original 986 the cap being 225 on my 04 2.7 (series 1 let's call it). Now with the 2nd gen motors they have upped the hp a bit. Like you said moving the obvious graph up a few hundred rpm and thus power and a bity of torque. My motors redline is 7200 and yet max power is at 6450 I think (but it really goes flat above 6k).
Ultimately if I could move that graph up to say max power at 7000 while adding headers, intake etc should get me close to 250. It would be more enjoyable to drive (pulling to redline) as apposed to falling flat at 6k. If all goes well it will be fun trying anyway.
I love tuning chat
P.S. I found out that contrary to what I thought before, Remounting the first o2 sensor to the cat (in the case of a high flow system, the one that WAS at the pre-cat) is not good. You have to extend the harness leads to the o2, that's bad. And by leaving it very close to it's original position but now on the headers (just past the collector) is the best shot and for no cel. Header wrap/jethot coating would probably help in this regard as well keeping the inside HOT for proper o2 reading. Neil @ Orton said he does this all the time with no cel's.
04 Boxster 2.7
Old 01-25-2005, 04:55 PM   #26
if you had a set of headers tuned for 7000 revs made, programmed ecu to match, added a larger throttle body / smooth intake, then you'll see 270HP IF the valves are large enough (not sure what the stock diameter is).
that assumes 150F manifold intake temp, .25 psi manifold pressure increase, no thermal efficiency increase, lambda=.8. Just the RPM increase alone, if the ecu has enough play to tune to this RPM, would give you 253. Add everything else and you get your 100HP / L.
insite
'99 Boxster
3.4L Conversion
Old 01-26-2005, 09:09 AM   #27
Does anyone know the valve diameters or port areas for these cars? If we can find those, we can calculate the theoretical and most likely HP limits of these cars (without doing any serious engine work first).
insite
'99 Boxster
3.4L Conversion
Old 01-27-2005, 09:29 PM   #28
Lux
Insite,
Good stuff, man.
Fletch,
Custom mapping will yield the highest gains for sure. But even then it's still minimal gains. Dyno charts are great and all but you need to know the facts behind the numbers. Showing gains on 94 or 104 octane gas means nothing since we only have 91 in CA.
Lux is offline   Reply With Quote
Old 01-28-2005, 04:58 AM   #29
Automon's Avatar
Why only 91 in CA? I live in $hit hole USA (MI) and I can get octane up to 110, which I run in my bike but not my Porsche
Automon
Automon is offline   Reply With Quote
Old 01-28-2005, 08:04 AM   #30
We can get 100 @ some Shell stations too!
You just have to look for it. You can blend to get 93 or 94. Try this blend chart if you need it.http://members.aol.com/SteveL1994/public/OctaneChart.xls
04 Boxster 2.7
Old 01-30-2005, 06:22 AM   #31
Originally Posted by Fletcher
But not the zero. Show us some legit dyno scans from a reputable and neutral shop. You will sell many if this is the case. We have all heard and read from many tuners the world over that the oem system is hard to beat. Ruf says 2-3 h.p. with their system. Something seems fishy here. It's hard enough to get 20hp from intake exhaust and ecu (especially without headers and cats).
Show us the proof, we will be happy to review it!
I just got my Dansk muffler and intend to install it over the next few days. My previous before/after showed 6+ bhp gain (at the wheels) from just the sports cat. I hope the muffler will yield about the same.
Look out for my report! I've not forgotten my intake kit. Just didn't have time to do it as the new year meant a lot of late nights for my line of work
clubhead is offline   Reply With Quote
Old 01-30-2005, 11:20 AM   #32
Send a message via AIM to Richard Truss
but what about the S?
all this talk about the 2.7... what, if anything, would this or any other mods do for the 3.2? dont get me wrong, i LOVE the ponies I got, but I always want more.
2000 S (3x Black)
Richard Truss is offline   Reply With Quote
Old 01-30-2005, 02:40 PM   #33
More, more more.
Richard you can expect very similar gains if not more with a 3.2.
Clubhead which cat's did you install? Which headers? Was this on a 2.7, what year do tell all please! I read over on PPBB that the dansk makes some power as well but it is extremely hard to pin anyone down with dyno results against baseline etc. I think we are starting to see some exciting stuff coming for the Boxsters tuning wise and the more choices the better
Every hp counts, my goal is 250. We will see what happens.
Anyone know much about the ignition on these cars? Just about everything can be improved on :dance:
05 is going to be a fun Year!!!!! :dance:
04 Boxster 2.7
Old 01-30-2005, 06:57 PM   #34
:dance:
I've Dansk headers on. You can find more details from my posting here http://986forum.com/forums/showthread.php?t=1805
It is not hard to pin down dyno results. All you need is time to go to/fro the dyno place after/before the installation.
Old 01-30-2005, 11:51 PM   #35
Lux
Automon
Well, I can get 104 octane down the street at the local 76. But at almost $5/gallon I'll pass. I'm just suspicious of tuning for OBDII cars. Even Jim Conforti of BMW tuning fame said that OBDII is a ******************** and that getting 5-6hp is about it. Of course he's talking about a different car (E46 M3) but since all cars since '96 have OBDII I'd guess that we're in the same boat.
Old 01-31-2005, 07:29 AM   #36
Brucelee's Avatar
Thumbs down
Remember in CA, the state govt has fiddled with EVERYTHING! Wouldnt be surprised if 92 and up was illegal!
Old 01-31-2005, 09:00 AM   #37
Richard -
when i get home this evening i'll run a workup on the 3.2's mathematical likely / theoretical limits with these change.
insite
'99 Boxster
3.4L Conversion
Old 01-31-2005, 12:13 PM   #38
thanks, insite....
i look forward to hearing what you have to say.
2000 S (3x Black)
