Old 07-31-2008, 09:40 PM   #1
Send a message via AIM to PSL-Boxster
0-100 mph run bad on cold engine?
just wondering the effects, say you startup the boxster and immediately start beating on it.. healthy?
PSL-Boxster is offline   Reply With Quote
Old 07-31-2008, 09:47 PM   #2
cold oil, not lubricating the parts,, cant be any good..
but not that big of a deal
06 Cayman S
07 RR HSE
Blkboxster is offline   Reply With Quote
Old 07-31-2008, 10:44 PM   #3
cold oil, as previously stated, doesn't get to all the parts quickly enough/in enough quantities.
The metal bits in the engine (read: almost all of the engine) expand as it gets warm and is designed be driven hard when its all expanded and what not
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
fragdude is offline   Reply With Quote
Old 08-01-2008, 04:16 AM   #4
Brucelee's Avatar
I assume you are just being provocative. In many ways, the answer is obvious.
Rich Belloff
Old 08-01-2008, 05:31 AM   #5
On the off chance you're serious.. what's the vin of your car so we can all avoid it when you go and try to sell it.
-- 02 Boxster S
-- Black/Black
-- Sideskirts/PSE
Sputter is offline   Reply With Quote
Old 08-01-2008, 07:14 AM   #6
9eighty6's Avatar
I would have to agre with Sputter ... not the best idea in the world. Porsches hold a lot of oil that needs to warm up properly. Is the engine going to explode? Probably not, but it will certainly wear a little faster.
1984 - 944 - The first one.
1984 - 928S - The loudest one.
2001 - Boxster - The best one.
9eighty6 is offline   Reply With Quote
Old 08-01-2008, 07:26 AM   #7
lol!!!!!!!!! perfect video
http://www.youtube.com/watch?v=nmDl3XBRDNw
06 Cayman S
07 RR HSE
Old 08-01-2008, 08:49 AM   #8
bmussatti
Posts: n/a
This will make your mechanic very healthy and wealthy.
Actually, I think if you keep the RPM's below 4,000 when doing an acceleration on a cold engine from 0-100 you should be OK. Not ideal...but just OK.
Old 08-01-2008, 07:08 PM   #9
Same Scenerio!!
I was just in this scenerio!!!!! My brother came over to see the new car (2000 boxster)....I knew exaclty what was going to happen......so I drove it around the block twice, made sure the temp was over 180....and parked it........9 minutes later my brother arrives......gets out of his 350z.....sure enough......he gets on it!
I don't know, if it were me I would think about it being cold....some people don't!!!!!
Dar01 is offline   Reply With Quote
Old 08-01-2008, 07:29 PM   #10
I constantly tell my brother not to drive his car so hard when its cold, especially because he has an air cooled Porsche. Dude guns it around like he stole it when its cold.
-H7 HID Upgrade
Old 08-05-2008, 11:07 PM   #11
There Is No Substitute.
rick3000's Avatar
Healthy...No!
It is best to stay under 4k RPM until the car has heated up to 180°. So you could accelerate slowly to 100mph without any problems. But I see no reason why you would want to do that. I wouldn't want to unnecessarily beat on my Boxster especially when that can easily lead to a pricey engine replacement.
Just wait the few extra minutes for the car to heat up, then rev it up to 6k+.
