Old 05-15-2008, 11:40 AM   #1
Tranny Issue
Howdy all,
New Boxster owner, new on forum. I've got a 97 Boxster with a tiptronic. When in automatic, after some hard driving or a while at interstate speeds, it downshifts VERY hard when I decelerate to stop or take off ramps or whatever. Sometimes it does it from 4 to 3, sometimes in 3 to 2. It shifts so hard the whole car jerks. Any help with this situation would be very much appreciated.
Thanks,
Maestro
maestro is offline   Reply With Quote
Old 05-15-2008, 12:15 PM   #2
Hey Teacher,
How many miles are on your boxster? and how many miles ago to you think the tranny fluid and tranny filter were replaced and how many years do you think the fluid that is it the tranny right now has been in the tranny?
If you think its been along time then you probably need to change both the fluid and the tranny fluid filter... cause you will get hard, late and agressive shifts when the fluid & filter are past there prime.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 05-15-2008, 12:49 PM   #3
I was told at purchase that the 75,000 mile services had just been done, and I've put about 1500 miles on it since. So if the fluid and filter are part of the 75,000, then they've probably been done. I'll get the stuff replaced regardless, but what else could it be if that doesn't fix it?
Old 05-15-2008, 01:46 PM   #4
Brucelee's Avatar
At the very least, I would do the fluid and filter on the car. See if that helps.
Rich Belloff
Old 05-15-2008, 01:46 PM   #5
hmmm, you'd have to look in your maintaince book to see if it says tranny service is apart of the 75k service. If its not that, im out of useful info
Carlos J Cazares
Old 05-15-2008, 02:27 PM   #6
or lack of ATF will do that... and soon your transmission will go bye bye
because not enough oil... check to see if its at the right level...
fu03steve is offline   Reply With Quote
Old 05-15-2008, 02:57 PM   #7
I assume ATF is automatic tranny fluid?
Old 05-15-2008, 04:52 PM   #8
Brucelee's Avatar
Yes, Automatics are very sensitive to having the right level of ATF and clean ATF. I would get your fluid and filter changed immediately.
Well worth the dough if it saves you the cost of a new TIP.
Good luck.
Rich Belloff
Old 05-15-2008, 05:44 PM   #9
Thanks folks, I've got an appointment monday.
Old 05-15-2008, 06:05 PM   #10
ATF= a tiny friend
jk
yes ATF= automatic transmission fluid
you need to not drive the car and figure out whats wrong first
because your tranny can go out quick especially you had been through with this problem for a while
Old 05-15-2008, 08:17 PM   #11
don't worry, i have my bike
Old 05-15-2008, 10:04 PM   #12
bike as in pedal to the medal
or
bike as in rooo roommm....
yes please fix the tranny issue
because in long term driving, it can
damage the tranny permanently
Old 05-16-2008, 12:02 PM   #13
haha, bike as in vroomm
Old 05-16-2008, 02:39 PM   #14
I had the same issues, hard downshift and occasional slip when upshifting. Changed the fluid and filter, no more problems.
releese78 is offline   Reply With Quote
