12-15-2007, 04:18 AM
She Won't Start
My 02S has been sitting in the garage for a week due to weahter. I decided to start her up this morning to bring her up to operating temp, but she won't start.
When I turn the key, everything lights up, but I get a tick, tick, tick sound. No engine turnover.
Any thoughts?
Thanks for help.
JFERRhttp:
Only problem with a Porsche is the traffic.
12-15-2007, 04:29 AM
07 Carrera S Cab
How old is your battery? If it's over 4 yrs., you're probably due for a new one. Not driving it for only one week shouldn't drain the battery that much.
12-15-2007, 04:36 AM
That is definatly the battery, get the car started and get it changed asap.
good luck
James
Had:
95 Vauxhall Tigra
99 DC2 Honda Integra type R
00 Audi TT 180 coupe
02 DC5 Honda Integra type R
01 Alfa Romeo spider 3.0 V6
01 Honda s2000
03 Audi TT Roadster 225
02 Porsche Boxster S silver/red Rolling on 19's
No w:
http://img.photobucket.com/albums/v4.../mycayman1.jpg
07 Cayman Guards Red/black on 19's
12-15-2007, 04:55 AM
If it's the battery, why is everything else working? Not enough power to turn the crank?
JFERRhttp:
12-15-2007, 05:02 AM
07 Carrera S Cab
Exactly. I had the same problem. Lights on the dash all on, but engine wouldn't crank. Not enough juice. Get the battery replaced, and all will be well. You can go to an autozone, sears, or costco...they all have compatible batteries for the Boxster, or go to dealer for an OEM Moll replacement (for a higher price). Make sure you have your radio code, as that will need to be reset after the battery change.
12-15-2007, 05:26 AM
It is definitely just a low battery, but you may not need to buy a new one. You can get a battery tender trickle charger and it will most likely charge it back to regular levels.
You will need one whether or not you need a new battery as it sounds like your car sits for long periods of time due to weather where you live.
I had this happen with my old Harley and the battery tender was a life saver. Has not happened with the Boxster yet as I'm able to start/drive it enough
Jeff Wilson
1989 911 Cabriolet
Grand Prix White/Black
33k
Stock except:
Turbo 7x9 Fuchs
SOLD!
2002 986S
Seal Gray/Black
Painted Center Console
18" Turbo Twists with rear spacers
Tequipment aluminum shift knob
Colored center caps
De-ambered tail lights/side markers
Stock except:
B&B catback exhaust
http://i29.tinypic.com/i6crck.jpg
12-15-2007, 05:43 AM
Whatever you do even if you charge it back up, get it swapped over, batteries are a pain and a weak one is awful all that needs to happen is you leaving the inside light on!!
James
Had:
95 Vauxhall Tigra
01 Honda s2000
No w:
12-24-2007, 06:12 PM
Yes, it's probably the battery. But I would suggest to check the battery if it has enough fluid and if not, fill it with some distilled water. Run the car to charge and bring some spare jumper cables or battery jumper just in case. If it starts working for you, you might be able to squeeze a little more life out of it. In the meantime, prepare for getting a new battery.
Hope this helps.
Geo
www.teamnio.com
