Old 08-27-2015, 10:29 PM   #5
I have two links for you:
Boxster Hacks and Instructions
Porsche Boxster Shocks & Spring Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
I like the balljoint press tool from harbor freight, although it does need some grinding/clearancing to fit around the shaft of the thick porsche ball joints. Easy if you have any sort of grinder (bench grinder, angle grinder, die grinder).
3/4" Forged Ball Joint Separator
I found it helpful to loosen the lateral a-arm bolts where they connect to the frame, so the lateral arm can be pressed down without fighting against torque in the rubber joint. This will upset the alignment, though. I didn't find it necessary to remove or loosen either end of the trailing arms (where they connect to frame or to lateral arm).
I believe any Macpherson spring compressor should work. You will need to remove the strut before being ready to compress the springs, though.
