Old 04-20-2015, 06:30 AM   #1
Send a message via Skype™ to paulhavel
Waterpump Replacement
Hi All,
I need to replace my water pump, on an 03 Boxster - does anyone know if you have to disconnect the lower hose and drain the coolant?
Thanks in advance
Paul
paulhavel is offline   Reply With Quote
Old 05-05-2015, 08:50 AM   #2
mikesz's Avatar
I have a 99 and yes I disconnected the lower hose to drain the system. I bought a 5 gallon storage bin to drain the coolant into and went to my local recycling station. I removed the front engine mount and replaced the bushing and also replaced the thermostat and added new coolant. There are several DIY. I referred to Pedro's and the Pelican book. it was actually easy to do.
99 Porsche Boxster
Old 05-06-2015, 02:20 AM   #3
water pump
I have also replaced my own water pump with the aid of the Pedro Porsche and Pelican parts technical guidelines. I would recommend marking the position of the bolts as you remove them from the pump since they are different lengths. I pushed mine in a piece of cardboard that I used as a template.
rem503 is offline   Reply With Quote
Old 05-06-2015, 03:23 AM   #4
kjc2050's Avatar
YES. This is a great tip.
Old 05-06-2015, 06:00 AM   #5
steved0x's Avatar
I did the same thing too. It turns out that the two holes in the water pump that have the dowels to help align the pump are the ones that get the longer bolts in case you forget to mark them.
Steve
Old 05-06-2015, 08:36 AM   #6
Make sure you get an oem metal gasket. I made that mistake and used the paper gasket and had to take it off and reinstall the metal gasket.
antny is offline   Reply With Quote
Old 05-07-2015, 05:16 AM   #7
mikesz's Avatar
yes what they said, cardboard and metal gasket. You may also want to replace thermostat and front motor mount while you are at it.
99 Porsche Boxster
Old 05-28-2015, 07:37 PM   #8
madmodz's Avatar
Agreed! I would do the belt also since you got the water pump off.
madmodz is offline   Reply With Quote
Old 05-29-2015, 08:08 PM   #9
That was perfect timing. I also have to change the pump out. Thanks for the tips - Anyone suggest a good parts supplier that ships to Canada?
Thinking I will do the Tension-er also as it has a minor amount of play in it.
Duezzer is offline   Reply With Quote
Old 05-30-2015, 03:34 AM   #10
WillH's Avatar
AutoPartsWAY.ca Canada 2001 Porsche Boxster Engine Water Pump in Canada
Used them for motor mount and it came out slightly cheaper than using ECS, Amazon, or Pelican. The shipping and exchange rate comes into play...
Edit,
I see autopartsway.ca is only showing the metal impeller model right now though.
Old 06-06-2015, 11:12 PM   #11
It won't drain a whole 5 gallons if you don't remove the thermostat, but will drain more than 1 gallon, so if you use a drain pan, do expect to use a deep one. It helps if you jack up the back right of the car to prevent a whole ton of coolant from draining out. Also, the innermost 10mm bolt for the pump is much easier to remove with a short 10mm swivel socket (or a 10mm short socket and a u-joint.) Take care and twist the hose off the pump's port, because you dont want to twist on that rubber T-joint in the hose.
BrakeExpert is offline   Reply With Quote
Old 06-07-2015, 05:32 AM   #12
mikesz's Avatar
when I drained my coolant I bought a 5 gallon storage container from Wal-Mart and used that to drain the coolant then took it to the recycling station to dispose of.
99 Porsche Boxster
Old 06-07-2015, 03:38 PM   #13
Ben-Auto-Design
Ben006's Avatar
Hi !
Can someone who changed his waterpump ... give is old waterpump to me ?
thanks !
Ben
Ben006 is offline   Reply With Quote
Old 06-09-2015, 06:33 AM   #14
Multi-Boxer Driver
Deserion's Avatar
Originally Posted by Ben006 View Post
Hi !
thanks !
Ben
What do you need an old pump for?
Also, coolant does need to be periodically changed, so this is the best time to do so. I was able to drain about 75-85% of the coolant from mine and added fresh.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-09-2015, 12:55 PM   #15
Ben-Auto-Design
Ben006's Avatar
mmmh, top secret project !
I want to use an electric water pump, and so I need to see how I can block the stock one before (and figure out the belt).
Old 06-12-2015, 03:51 PM   #16
Shacky
Do you use gasket sealer with metal gasket?
shacky is offline   Reply With Quote
Old 06-12-2015, 03:57 PM   #17
911monty's Avatar
Shacky; The metal gasket is installed dry, no sealant. Just make sure the sealing surface is good and clean.
Ben006; I have my water pump that is in good condition, no failure of bearing or impeller, if you want to pay shipping and work something out on next batch of shifters!!
