Old 02-19-2015, 02:31 PM   #2
I had a leak through the plastic membrane between the door panel trim and the actual door. Replacing the membrane and the ten attachment clips solved my issue. Where I saw water was at the base of the door panel on the carpet. It soaked beneath the speaker and back.
qwerty is offline   Reply With Quote
Tags
water leak roof
