02-04-2015, 01:38 PM
Refinishing OEM Turbo Twist Porsche Wheels
02-04-2015, 01:40 PM
02-04-2015, 01:41 PM
I then worked the filler down with a 3M 320 grit sponge block moving onto 400 and 600 grit wet / dry paper wrapped around rubber profiles for the center / spoke areas and used a wooden paint stir stick for the outside / edge areas. Patience required here, I filled / sanded 3 separate times to get it perfectly smooth. After that I scuffed up the finish with a Scotch Brite type pad to ensure a good bite for the paint.
After a wipe down with the Paint Prep I applied the Self Etching Primer:
After drying 24 hours I applied the Duplicolor Silver as a base coat prior to the Wurth (much more expensive) paint, Note how "Metallic" the paint is compared to OEM Porsche wheels:
02-04-2015, 01:43 PM
I then applied two coats of the Wurth paint on top of the Duplicolor, notice how much more uniform and silver it looks compared to the Duplicolor, MUCH more like the OEM paint:
I then utilized the Duplicolor Gloss Clear paint (2 thin, topped off by a third "wet" coat) to give them their final finish. Popped in the OEM centers and am still waiting on the new metal valve stems to be delivered from SunCoast:
I've paid to have wheels professionally finished in the past, but I got to admit I was floored at how these turned out using bomb cans when these were finished, I'd say they are 90 plus percent as nice as what I dropped money on for others to do in the past. Probably $50 to $70 dollars in materials used depending upon what you may already have lying around.
02-04-2015, 02:15 PM
You fargin icehole, you are gonna put your local wheel refinisher out of business
Looks fargin GREAT!!!
02-04-2015, 02:29 PM
Nice work!
BTW - the wife must be very understanding of the dual use of the bath tub or she was out of town at the time.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
02-04-2015, 02:39 PM
Originally Posted by Porsche9
Nice work!
LOL! He can't possibly be married:
1) Using the bathtub to clean wheels
2) Free time to do this kind of project!
Well done! Thanks for posting!!
02-04-2015, 02:42 PM
Nice work!
That was done in the basement tub brother, there are 3 others in the house lol. I'm still waiting for the "Garden" tub to produce tomatoes or something..............
02-04-2015, 03:17 PM
depending on where you live, it could be a cash crop
02-04-2015, 03:30 PM
Looks fantastic!
02-04-2015, 04:10 PM
Very nice!
Thanks for a detailed write-up and pics!
Rick
02-05-2015, 07:17 AM
Sweet recovery!
Now all left to do is using the remaining degreaser liquid to clean up the tub real good loll Mind you oil based residues in the bath combat germs..... you could well use that reasoning if you get in trouble with the wife :/ hmmm
Nice work, all worth the effort imo (wheels important man)
02-05-2015, 04:03 PM
Very nice looking pictures! Especially with spray-paint..? Well done!
2004 Boxster S manual
02-06-2015, 08:39 AM
Moderator
Nice job, wheel refinishing with the son too!
02-10-2015, 01:42 PM
I suggest that self-etching primer should be use for bare metal or near bear metal, otherwise use regular primer.
