02-27-2014, 12:51 PM
Bumperettes removal from 2001 986
I want to paint the black bumperettes on my 986 but can't seem to remove them from the bumper. I have no problem getting the bolt out on each but can't seem to get the bumperette to fall off and I didn't want to force it. Once the bolt is out do I just tug the bumperette straight back or do I have to slide it or tilt it to remove?
Thanks for the help
02-27-2014, 01:24 PM
petrol head
would like to help but no bumperettes over here in the uk, sorry mate
02-27-2014, 01:56 PM
Never mind, got them off, they just needed a good tug (don't we all  )
02-28-2014, 11:41 AM
I've done this job a few times using a bumper paint. I worked great and holds up quite well. I'm sure you'll be proud of the results.
02-28-2014, 01:57 PM
Ordered my primer, paint and clearcoat from Touch Up Paint and Accessories | AutomotiveTouchup
have used this vendor before and liked it. I highly recommend their products, both pens and spray cans for your painting needs.
In about 2 weeks I will be sporting some Slate Grey Metallic bumperettes.
03-12-2014, 06:43 AM
I have removed mine completely along with the brackets. Ordered a piece of ABS plastic, cut to size and attach to the area where the bumperettes were and license plate. I think I will leave it black. My car is arctic silve and I think the black would be a nice accent piece. But I might paint to match car.
99 Porsche Boxster
03-12-2014, 07:23 AM
That sounds clean. Post a pict when you can!!
03-26-2014, 06:24 PM
Here is rear bumper with bumperettes removed and filler plate installed.
99 Porsche Boxster
04-01-2014, 07:43 AM
Bumperettes Painted
I finally got a chance to paint my bumperettes. Bought primers and paints from Automotive Touch up Paints. Project came out beautiful, even on a Metallic Slate color. Did the whole project for less than $50 delivered, with plenty of paint left over for future needs.
I used Adhesion promoter (3 coats), Primer (3 coats), then wet sanded with 1000 grit, Paint (5 coats), Clear Coat (5 coats). Put bumperettes in a cardboard box with a 40 watt lightbulb and let them cure for 4 hours, voila!
I'll post some pics once the sun comes out again. We haven't had rain all winter and now we actually are getting rain for the next few days, go figure.
04-01-2014, 11:38 AM
"filler plate"
That's a good idea.
04-01-2014, 12:45 PM
@Randall,
there is a company that sells a "filler plate', aluminum for $200. I bought a piece of ABS, made my template then had it cut by a glass shop. Much less than $200!
99 Porsche Boxster
03-19-2018, 02:22 PM
2000 Boxster S
I am going to be tackling this 'filler plate" project this weekend, painted to match car. Wish me luck, will post a pic when complete.
03-21-2018, 02:31 PM
UK Boxster don't have bumperettes fitted but I wanted a contrast around my licence plate so fixed some black vinyl in the recess.
