Old 10-11-2011, 09:21 AM   #2
Originally Posted by Ralphz View Post
Hi All,
I'm new in this forum, but I enjoy driving my Boxter '97 since new (only 14,000 miles...).
I just changed the air filter according to some instructions posted in the Pelican Auto Parts website (great site by the way...), and all went well until I started to put everything back together: now I cannot connect the linkage back, the hole is far back than the pin. I tried several times with no luck, I cannot find a way to move the linkage forward. The closest that I can get is about 3/4" away from the correct position.
Any ideas?
If I follow which part you're talking about, I had to loosen the 19mm bolt (helps to use a breaker bar for leverage) that holds the boomerang shaped piece. You don't have to completely remove the bolt, just enough so you can move the push rod into place, then attach the clip and tighten back the bolt. By the way, I didn't have to disconnect anything to change the airfilter.
keithl is offline   Reply With Quote
