Old 04-25-2023, 04:58 AM   #1
Question Best way to mount a brake pressure sensor?
Where do you install an adapter for a brake pressure sensor? I saw a product which uses a hose and an adapter, but for several reasons I would like to keep hardlines wherever possible.
Has anyone made an adaptor for the hardline?
1990 944 Turbo
2007 Renault Clio RS 197 (Sold)
1998 Boxster 2.5L Track Day/ Race Car
2011 Mistubishi i-MiEV
Norway
Bebbetufs is offline   Reply With Quote
Old 04-25-2023, 10:37 AM   #2
The Radium King's Avatar
how about on the bottom of your shoe?
Old 04-25-2023, 12:37 PM   #3
That one has been installed, but needs calibrating
The other one is for datalogging. I'll only be able to hit the track 4-6 times per year, so might as well have some data to look at.
1990 944 Turbo
Norway
Old 04-25-2023, 02:15 PM   #4
iirc durametric can grab data from abs unit?
Old 04-25-2023, 02:38 PM   #5
Interesting.
That may be accessible through an OBD2 dongle. I'll need to find out more about that.
1990 944 Turbo
Norway
Old 04-25-2023, 05:42 PM   #6
986tate's Avatar
Use brass T fittings and branch off where the jounce hose connects.
986tate is offline   Reply With Quote
Old 04-26-2023, 12:52 PM   #7
Is the jounce hose the line coming off the front of the master cylinder?
1990 944 Turbo
Norway
Old 04-27-2023, 10:49 AM   #8
986tate's Avatar
I meant at the wheel corner where the rubber or stainless line connects but it might be safer at the master. You just have to know what circuit you are tapping into. Do you have only one sensor?
Old 04-28-2023, 11:36 AM   #9
Unfortunately, the sensor are fairly pricey. I only have one for now. I'm going to machine an adapter and plump it to the outlet from the master cylinder.
Does anyone know which outlet from the master is for the front brake circuit?
1990 944 Turbo
Norway
Old 05-05-2023, 03:46 AM   #10
My brake pressure sensor is T'd into the front brake channel line between the master cylinder and ABS unit.
P Cars: 1997 Spec Boxster - SPB #94 / 2022 Macan GTS / 2018 Panamera Turbo Sport Turismo ---- Other cars: 2021 F-250 Diesel / 2019 Golf R
Gone: 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches.
PCA National DE Instructor #202106053
nickshu is offline   Reply With Quote
Old 05-07-2023, 03:14 AM   #11
Thanks. That's what I'll do too. Did you make the T-piece or buy it somewhere-? If you made it, do you remember what hardware you used?
1990 944 Turbo
Norway
Old 05-15-2023, 05:28 PM   #12
I don't know it was done by the guy who built my car, it is a stainless braided line with crimped fittings, could have been custom made by a hose shop, not sure.
Old 05-16-2023, 11:35 AM   #13
986tate's Avatar
My company does brake testing so we use those fittings all the time. We have to have them made for all the different sizes and flares.
If you weren’t in Norway I might be able to pinch one for you.
You might get lucky finding a T from a Porsche rear brake system where it splits to go to each rear wheel
Old 05-18-2023, 11:18 PM   #14
Thanks guys.
I was thinking about the rear T-piece, but it the lines fort the rear are thinner than those coming from the master cylinder.
Do you know what type of flare I need? I have access to a reasonable crimper, but the lines are very hard, so I'm not convinced It will work.
1990 944 Turbo
Norway
Old 05-20-2023, 05:10 AM   #15
Thanks guys.
I need to drag my car out of my storage to my lift at my house tomorrow. I can grab some pics.
Old 05-20-2023, 09:40 AM   #16
Thanks, but there's no need. I don't think a picture can give me the info I need. I red somewhere else that you're running a 997 master cylinder. Is that correct? I may want to go that road so I'm going to hold off on mounting the pressure sensor until I've got all the information I need to make my mind up.
Update. I've decided to make a banjo bolt and adapter similar to that used in the cup cars. I've got a mill and a lathe, so it should be the cleanest and cheapest solution.
1990 944 Turbo
Norway
Old 05-21-2023, 01:31 PM   #17
Sweet. John is the man, he lives in my area, hopefully you got one of the bolts he had made.
