Old 11-29-2018, 07:01 AM   #1
Swiftmotoring's Avatar
996 GT3 Swaybars
Will 996 GT3 adjustable swaybars fit my 2000 Boxster without modification and is it a sensible upgrade? Thank you.
Swiftmotoring is offline   Reply With Quote
Old 11-29-2018, 07:53 AM   #2
steved0x's Avatar
Front will fit [edit: will fit but requires the shorter tarett drop links] but not the back... I think I saw that set, came with the drop links too? I think it is a good price and you could probably resell the rear to someone and pick up the Tarett GT rear bar to go with the front.
Old 11-29-2018, 11:21 AM   #3
Topless's Avatar
Depends on your plans. Just bolting on different sways is pointless but if you are using them to fine tune car balance it makes sense. Running square you could just change the front, and use a GT3 bar to reset cornering balance. As others have said, the rear does not fit.
In TT competition, my brother just added a M030 rear to get the car to rotate more easily. A very low cost mod that worked great and he was fast.
Old 11-29-2018, 01:40 PM   #4
JayG's Avatar
Both of you are fast
Old 11-29-2018, 02:52 PM   #5
Thank you for the quick responses. My goal/plan is to simply continue to develop my 2000 Boxster into a quick and enjoyable track car without regard or consideration for any rules. I have a 1986 944 racecar that is governed by a rule book, the Boxster is simply an enjoyable track day car. Any suggestions?
Here is a picture of the Boxster.
Old 11-29-2018, 05:37 PM   #6
steved0x's Avatar
You're fast enough already, i can barely keep up with you as it is...
Old 12-18-2018, 04:04 PM   #7
jaykay's Avatar
All,
Is there any that have their GT3 front bar set up on anything other than full soft?
Is it felt that this is still too much bar for a staggered car.....225 tire?
986 00S
Old 12-19-2018, 09:15 AM   #8
I run full soft and don't find it to be too much front bar, especially when paired with adjustable rear bar.
Old 12-19-2018, 10:19 AM   #9
steved0x's Avatar
What is your rear bar setting, with apologies if you have already said it (probably in response to my same suqgestion) on another thread.
Old 12-19-2018, 04:02 PM   #10
1 off full soft on the tarett bar
Old 12-19-2018, 04:19 PM   #11
jaykay's Avatar
Thanks man....what size tires / TW rating correspond to this particular setting?
986 00S
Old 12-20-2018, 04:06 AM   #12
I run 235/255 nitto nt01 (100tw i think)
