Old 11-15-2018, 03:36 AM   #1
truegearhead's Avatar
Accusump Install (oil cooler vs. filter plate)
What are your thoughts on the install below vs. the typical install at the oil filter?
Accusump installation.
2003 911 C2
NASA HPDE Instructor
Old 11-15-2018, 04:35 AM   #2
Also, those of you running the Accusump through the oil filter what sandwich plate setup are you using?
2003 911 C2
Old 11-15-2018, 08:50 AM   #3
Cool approach..
I believe the main question is wether this is an efficient place for inserting the oil, from a lubrication perspective. Would need to se a schematic for the M96 oil Circuit, where can that be found?
Old 11-15-2018, 10:58 AM   #5
Looking at this it doesn’t seem to make much of a difference.
2003 911 C2
Old 11-15-2018, 11:24 AM   #6
The Radium King's Avatar
also not sure if you've seen this thread regarding sandwich plates and filter options ...
http://986forum.com/forums/boxster-racing-forum/73515-accusump-some-data.html
or the titaniumdave comment in this thread about the epc ...
http://986forum.com/forums/boxster-racing-forum/69570-racers-do-you-worry-about-oiling-issues-do-you-just-drive.html
Old 11-25-2018, 02:58 PM   #7
AZ986S's Avatar
This is my setup. I use a Mocal remote oil filter take-off plate, but with that set-up, I still needed the LNE Spin-on adapter.
TuneRS makes a really nice all-in-one take-off plate that does not require the LNE adapter and has a built-in check valve.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 11-26-2018, 01:15 PM   #8
I´m starting to like the oil-cooler approach, should get the job done and it´s very clean with a minimum of components.
Old 11-26-2018, 04:20 PM   #9
jsceash's Avatar
My sandwich Plate.
