Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 02-24-2012, 10:19 AM   #1
SPB racer
OK..... I just watched it again and every time you brake (or even slow down) the oil pressure drops. What aren't you seeing?
Right or left is different for some reason or another and typically these cars starve for oil under extreme left hand turns - or right hand if the engine is in backwards such as a 996. No idea why, just quoting what I have heard and what I have observed. Just for the record this does require in excess of 1g for sustained periods. Doesn't look like you would be even approaching 1g in the video you displayed and none of them look particularily sustained.
Brad, you would know better than me - does the behavior of Pedro's oil pressure gauge look right to you?
In my car whilst on the track the pressure reads 80-100 lbs (varying by temperature only) all the time if I am anything above idle. In your film your car is constantly dropping if you do anything other than drive straight and flat. Only three possible explanations that I can think of - the car is starving for oil because it is too low, there is something wrong with the oiling system and it cannot deliver the required pressure the minute the revs drop (such as braking or turning) OR there is something wrong with the gauge. Since it is a noname gauge with a dubious wiring setup I would be inclined to believe the later.
Laurie
Jittsl is offline   Reply With Quote
Old 02-24-2012, 06:32 PM   #2
ppbon's Avatar
The other option is ...
.... my particular gauges are electrically operated.
The sensor sends a signal to the gauge which has a servo motor so it reacts to every change of pressure quickly and accurately.
Many analog gauges are. Very slow to react do it seems that the pressure is steady when it's actually not.
Again, there is nothing wrong with my gauges.
What you may see as a pressure drop under braking is just the normal pressure drop from decelerating the engine's RPMs.
On the track the oil temp is much higher than normal and therefore less viscous do it also allows for a quicker drop in pressure than you'd normally see.
The video may not look it but almost every turn generates close to 1G lateral.
Happy Boxstering
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
