Old 02-10-2007, 07:43 AM   #1
What r my options:battery is dead and trunk not opening
Ok, so for these of you who haven;t read my first post, my Boxster battery died as it was super cold here in STL this week and I was looking for advise to buy a new battery.
I finally decided to take care of it this WE to finally realize that the trunk isn't opening. Somehow my alarm went off when I tried it and stoped after wiggling the key into the ignition...Now what are my option other that jumping at the fuse box to get the hood up? Thanks!
Thanks for your time,
Vanessa
99 silver Bosxter
99 silver BMW 323i
http://i105.photobucket.com/albums/m...rscheseule.jpg
vouvoune is offline   Reply With Quote
Old 02-10-2007, 07:48 AM   #2
You could try to get one of those battery chargers/conditioners that plug in to your cigarette lighter jack. I don't think I'd trust one of those jumpstart things through that jack, though - the leads are too small to handle enough current to crank your engine.
Anyway, if you found a conditioner or charger that could be plugged into the cig lighter, you might get enough juice from that to pop the trunk. Or just leave it plugged in for a couple days, and have a nice charged battery.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
Old 02-10-2007, 07:56 AM   #3
There should be a cable release under the right front fender behind the bumper cover in early cars.
If you get alarm from connecting external battery just lock/unlock driver side door with key.
I would think Fray is probably right about getting enough juice from cigarette jumper to pop the hood.
Recommend against prying the lid open with a crowbar.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
Old 02-10-2007, 08:00 AM   #4
well that was my first thought but am a little hesitant about these charger...I had a jump starter(lighter to lighter) and it really did not work (with another car) so i dont really trust that the charger works either...
I guess worth case scenario (as you mentioned) it will give me enough in order to open the trunk...
thanks!
Vanessa
99 silver Bosxter
99 silver BMW 323i
Old 02-10-2007, 08:30 AM   #5
thanks!
The cig lighter to cig lighter connection thing... I seriously doubt you'd be able to actually jumpstart a car from it. Again, the wires are too small to handle the current needed... plus the running car's circuit fuse would probably blow.
Although a charger could charge the battery, albeit VERY slowly, via the cig lighter socket.
Old 02-10-2007, 08:49 AM   #6
Vanessa.I purchased one of those Black & Decker battery chargers. I'm going to plug it in now. I'll let you know if I get enough juice to pop the hood. I'm thinking it might take awhile.
2006 Boxster
RevDice is offline   Reply With Quote
Old 02-10-2007, 09:06 AM   #7
Vanessa... The battery booster worked immediately to pop the hood. We've had such cold temps here, I'm afraid my battery is frozen, so I'm not going to charge or jump it on the car. I'll take it out and bring it inside to thaw. Won't be surprised if I need to replace it. Battery Tender for me immediately after storage next year.
The Black & Decker product is the Simple Start Vehicle Battery Booster. I got it in ebay. Couldn't find it locally.
Good Luck.
2006 Boxster
Old 02-10-2007, 09:30 AM   #8
Good Luck.
Walmart, they have the trickle charger for $17, have had one on my 911 for 4 years so I bought another for my 986. Not as pretty as a factory Porsche charger but they are all probaly made in the same factory in China.
Thom
'81 911 SC ROW = The Money Pit
'02 Boxster S = Daily Driver
thomschoon is offline   Reply With Quote
Old 02-13-2007, 06:48 AM   #9
well, the plug in charger worked just fine (i bought one at Walmart) and replaced the batteyr all together with a Duralast as I lked their 7 year warranty...Thanks for the input you guys!!!
Revdice: Thanks for the update, it work right away for me too...
Vanessa
99 silver Bosxter
99 silver BMW 323i
