Had a prior thread on this, thought I fixed it but apparently not.
1998 Boxster 986.
When opening the passenger door using either the inside handle or outside handle, the window drops so long as the handle is held, but once either handle is released the window goes back up to the closed door position.
Originally, only the outside handle exhibited this temporarily down, then back up when released behavior, so I removed the door panel, found that the outer door handle's microswitch had become disconnected (maybe he window had caught it when lowered as the microswitch wiring was not secured but rather hanging free?), reconnected it and put the door back together.
After this repair, both handles started to exhibit this window drop then up on release behavior.
I wasn't as detailed as I usually am in documenting tests/changes I've done, but I do believe that both handles started behaving properly after a programming sequence -- raising window then holding switch for 20 sec, then doing the same after lowering window -- but then reverted to the window drop then up on release behavior after a few cycles.
I also sprayed some silicon lubricant director into the lock actuator, and this also seemed to work for a few cycles before returning to the window drop then up on release behavior.
Given that both the inside and outside handle are exhibiting this behavior, I am thinking that it is not the handle microswitches that are the problem but rather the lock actuator itself.
However, before I start throwing parts at it, I wanted to see if anyone has had this particular problem or can otherwise tell me what my next steps should be.
Thanks in advance for any help.
