Old 03-06-2026, 08:14 AM   #1
Ignition Switch Question not returning from Start to ON
Ignition Switch: The key is not always springing back fully from the START position to ON. When it doesn’t return all the way, my wipers won’t work until I manually click the key back a little.
The key action also feels slightly stiff.
I recently replaced the ignition switch with the URO white switch.
- Has anyone experienced this with the URO switch?
- Is there anything in the key cylinder or mechanism that can be lubricated safely?
- Could the electrical switch install be slightly misaligned?
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
Old 03-07-2026, 10:35 AM   #2
KevinH1990's Avatar
I installed a URO ignition switch that failed after about a month. I replaced it with another URO switch and that one has been fine for several years. I have seen several threads that suggest URO's quality control may not be at the same level as some other brands.
Given the symptoms you described and my experience, I think it's possible that you installed a defective part.
Good luck.
Old 03-07-2026, 10:54 AM   #3
Thanks. I have cleaned my outer Ignition switch and hoping for the best now. Will report back if it solved it or not.
https://youtu.be/ixmVADj_Czo
Old 03-10-2026, 04:17 PM   #4
I’m not a fan of URO parts.
I bought a replacement corner headlamp lens for my drivers side headlamp with the washer nozzle. It wouldn’t even fit. I had to use an exacto knife to do some surgery on it and finally got it to click on. When I installed the headlamp it cracked.
Bought a genuine Porsche item and it clicked on easily and has been fine. The URO didn’t sit flush either, looked bad.
I should have spent the extra 20$ and saved the hassle and the money spent on an inferior part. I think a used genuine part would better than a new URO item.
DonQ is online now   Reply With Quote
Old 03-11-2026, 04:36 PM   #5
Coaster's Avatar
I had the exact same URO corner light issue. Used a razor to shave it down and it still doesn't sit flush.
Coaster is offline   Reply With Quote
