Old 09-11-2025, 12:05 PM   #1
Does this rumbling noise sound like the idler pulleys?
I have a rumbling noise that occurs at idle most of the time, moreso when the car is cold. I managed to capture the noise in this video.
Before I order the 2 idler pulleys, am I on the right track here?
Thanks as always in advance!
BoxsterInTheSun is offline   Reply With Quote
Old 09-11-2025, 12:22 PM   #2
If you remove the belt, you can turn ALL the pulleys one at a time to see which one needs attention..............
Old 09-11-2025, 12:37 PM   #3
Ah great! Assume I'm looking to be able to recreate a noise of some description while turning them by hand?
Old 09-11-2025, 02:05 PM   #4
Yes, a rumble or similar sound and feel.
Old 09-13-2025, 05:19 AM   #5
"50 Years of 550 Spyder"
10/10ths's Avatar
A bad idler pulley….
….is very bad news.
I have seen three different Boxsters go up in flames after an idler pulley failure.
Belt friction set that thing on fire.
Old 09-14-2025, 02:09 PM   #6
Originally Posted by 10/10ths View Post
….is very bad news.
I got access to it today while I'm waiting for time to take the belt off. I can hear the noise much better with the access panel off.
Can someone take a look at this latest video that shows the rumble a lot better and let me know if I'm on the right track with the pulleys, or is this loud enough that it could be something else?
Regardless I'll be taking the belt off to check the pulley bearings as @JFP in PA mentioned, but wanted to check in case this is something else that I would need parts for so I can get them ordered.
Old 09-14-2025, 09:55 PM   #7
I also think it is one of the bearings of one of the pulleys. Take the opportunity to renew the belt as well. If the AC compressor might be the culprit, switch it on and off and check the difference -- if there is any.
Old 09-15-2025, 03:49 AM   #8
Registered Member
With all due respect, taking the belt off is about a 30 second operation. Just do it.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
Old 09-16-2025, 07:33 PM   #9
Got the belt off tonight and took a look. I'm not completely sure what I'm looking for to know if the pulleys are "bad" or not. I took a video of me rolling them, would anyone mind taking a look and letting me know how they seem?
I'm not sure that anything I'm hearing here would equate to the noise I hear in the original video I posted, but maybe that's all it takes?
Thanks as always for the help!
Old 09-16-2025, 09:01 PM   #10
That bearing you rotate by hand is gone. Should be basically silent when it is good.
2001 996 C2 Manual
Old 09-16-2025, 09:06 PM   #11
Thank you so much! So the first and second ones in the video ( the upper and lower idler pulleys )? The tensionser pulley doesn't seem to make noise.
Old 09-16-2025, 11:19 PM   #12
You identified them by yourself: "noisy".
Old 09-17-2025, 10:08 AM   #13
I have just ordered replacements for the first two ( upper and lower idler pulleys ), I figure I might as well just replace them anyway. The tensioner pulley seems "stiff" to me, but isn't noisy at all, maybe that's how it's supposed to be?
Old 09-17-2025, 10:54 PM   #14
Correct, if it's not running rough or noisy it should be fine. And do not forget to engage the clutch of the AC-compressor to rule that bearing out.
Old 09-18-2025, 08:27 AM   #15
piper6909's Avatar
Looks and sounds to me like the first two you spun need replaced. The first one may be louder and definitely the one causing most of your noise, but the second one isn't far behind. When it spins freely like that, it means that the grease is gone. The third one is quiet, and quickly stops, which means it still has grease.
2010 Subaru Forester
Old 09-21-2025, 05:47 AM   #16
Toppy
Toppy986's Avatar
Any opinion on just replacing the bearings, instead of the complete assembly
1999 Boxster
Arena Red/Graphite Grey Interior/Black 03 Top/550 All Red Tail Lights
Toppy986 is offline   Reply With Quote
Old 09-21-2025, 11:18 AM   #17
1998 Boxster Silver/Red
Pull the respective pulley... pop off the plastic retaining ring... examine the bearings... bad? Replace with new bearings... press in some grease (by hand) reinstall the plastic retaining ring... reinstall the pulley.
Bearings good, upon inspection? Remove the bearings... spray clean the bearings and the pulley... reinstall the bearings... regrease... reinstall the ring... close it up and reinstall the pulley.
Go driving.
1998 Porsche Boxster
Old 09-22-2025, 03:16 AM   #18
Registered Member
You can certainly save some money by doing so.
https://burnerscars.blogspot.com/2016/10/how-to-repair-bad-idle-pulley.html
Tom Coradeschi
03 Boxster
Old 09-22-2025, 09:03 AM   #19
Quick update
Installed the new upper and lower idler pulleys this weekend and put everything back together. Long story short, the rumble is still there. Maybe a little better, hard to tell. Regardless those 2 pulleys needed switching out anyway so not a complete waste of time.
Back to the drawing board, but at least I eliminated 2 of the potential culprits.
Old 10-04-2025, 03:26 PM   #20
Seems to be the alternator
Had another chance to revisit this today, the rumbling is almost certainly coming from the alternator. I was able to very this by using a long screwdriver as a "stethoscope" and the noise is far and away loudest when placed on the alternator compared to the waterpump or AC compressor areas.
What is my path of least resistance on fixing this? New alternator? New to me alternator? Is it possible to just replace the pulley? I'll be doing this myself so any advice is much appreciated.
Here's what I have:
