Old 04-27-2025, 09:19 AM   #1
Rob175's Avatar
I don't believe that's the way it works on the older systems like on my 98'.
I believe the press of the key FOB's button acts like many remote controls, It turns the system on and THEN the system "looks" for the code to unlock the car. (that's why there is a button on the fOB in the first place)
My Harley Davidson and BMW key FOBs work the exact opposite way. Those FOBs are always trying to communicate, which is why I keep the FOB far away from those vehicles so as to not constantly communicate and wear down the FOB batteries prematurely. They are "PROXIMITY" FOBs, while my 98' Porsche FOB is only a basic radio transmitter that must be activated by pressing in order to begin communicating..
I assume the newer Porsche FOBs are typically "proximity" FOBs like most of the industry so as you get closer to the car the car responds.
98' Boxster
Rob175 is online now   Reply With Quote
Old 04-29-2025, 02:18 PM   #2
If there was no power enabling a receiver of some sort, how would that receiver ever get turned on? And there has to be some power to enable the immobilizer to send the signal to turn on the circuitry to unlock the car.
Yes key fobs of different model years work differently, but the basic principle of needing a listener is still the factor.
Big power drain, no. But there is a very small drain even an hour after you have turned off the car and walked away from it. If there wasn't, you'd have to always use a mechanical key which doesn't require that listener to unlock. Not something that a healthy battery can't handle in normal situations. But a car left long enough ...
Why else do we get battery drain and condition questions after winter hibernation season ends?
Prior '70 914, '99 986 Boxster, '01 Boxster S
Old 05-13-2025, 04:26 AM   #3
"50 Years of 550 Spyder"
10/10ths's Avatar
Also….
….remember that these cars go into a “Deep Sleep” mode after being parked and locked for three days.
When in this mode, you must insert the key into the door to open and then stick the key into the ignition and turn it to accessory mode to disable the alarm.
10/10ths is online now   Reply With Quote
Old 05-13-2025, 05:56 AM   #4
Rob175's Avatar
My 98 Boxster doesn't do that exactly...When locked for its winter storage, I do need the key to unlock the doors...BUT I'm not required to put the key in the accessory position, or for that matter I don't need to do anything ....no NO ALARM SOUNDS. (yes, my alarm works)
Typically, I just unlock with the key, start the car and drive off.
98' Boxster
