Old 08-02-2024, 01:17 PM   #1
battery ground disconnect
It has been suggested that when doing electrical work, that the ground cable from the battery be disconnected before doing said work. What, if anything must be re-programmed when the cable is re-connected? 2002 986
Elliot Cannon is offline   Reply With Quote
Old 08-02-2024, 01:55 PM   #2
I've done this many times ('01S). The only thing I've had to do when re-connecting is to input the radio code. Everything else sorts itself out on its own..
Old 08-02-2024, 02:20 PM   #3
On my 2002 I always have to reset the clock. You might also have to reset the window full up calibration. It's hard to tell if that gets messed or not.
Lowski is offline   Reply With Quote
Old 08-02-2024, 04:57 PM   #4
It depends on how long it’s disconnected. But clock, radio code, and window auto up/down calibration.
spinjockey is online now   Reply With Quote
