Old 07-30-2024, 07:47 AM   #1
SHB986S
speedometer/odometer intermittent
Last night on an evening ride, my speedometer and odometer started working intermittent, could it be a loose wire? or the speedometer pickup gone bad.
Samuel Best is offline   Reply With Quote
Old 07-31-2024, 05:26 AM   #2
1998 Boxster Silver/Red
Yes, and yes.
1998 Porsche Boxster
Old 07-31-2024, 05:32 AM   #3
KevinH1990's Avatar
https://youtu.be/z4cB7HQDAvo
This link shows the process for removing the gauge cluster. I recommend that you remove the cluster and check to be sure that all of the connectors are seated properly. If I recall correctly, I've seen posts that suggest the connectors and associated wiring can fail with age.
Old 08-01-2024, 08:34 AM   #4
SHB986S
THANKS everyone for the comments
