Old 12-14-2006, 08:18 AM   #1
Rear view mirror turning yellowish
Need some help here.
Since about a week ago, parts of my rear view mirror is turning yellowish and they are spreading like ink blots. Does anyone know what's causing this and is it possible to just replace just the mirror? I would like to avoid replacing the whole rear view kit, which according to the dealer is $389.
Thanks in advance.
8sum8 is offline   Reply With Quote
Old 12-14-2006, 12:00 PM   #2
Is it a standard mirror or auto-dimming?
Are the blots in front of the mirroring? It sounds like the auto-dimming stuff has gone bad or, even worse, maybe it's leaking. It's supposed to be nasty stuff if it leaks.
Chris.
http://www.lawlai.com/sig.jpg
ukchris is offline   Reply With Quote
Old 12-14-2006, 06:25 PM   #3
Chris.
Its auto dimming and the blots are behind the surface of the mirror.
Old 12-14-2006, 06:28 PM   #4
I can't imagine what it could be other than the auto dimming layer. You can get a regular mirror cheap but the auto-dimming one is about $300, I don't think you can buy just the glass and even if you could that would be the expensive bit.
Old 12-14-2006, 06:44 PM   #5
I would go ahead and pull the mirror off before the problem starts spreading to other parts of the car.
Happy Motoring!... Tim’05
http://i153.photobucket.com/albums/s..._kill/Siga.jpg
Dr. Kill is offline   Reply With Quote
Old 12-14-2006, 07:57 PM   #6
I agree. I'm not sure what mechanism the Porsche mirror uses but if it is the liquid / gel the stuff can be pretty nasty I unedrstand and might stain your interior if it leaks. Maybe you could post some pictures, if you scrap it I'd be interested in having a look inside to see what has happened.
Chris.
Old 12-17-2006, 03:43 PM   #7
Chris.
Thanks guys. Took your advise and replaced the mirror.
