Old 03-03-2024, 08:43 AM   #1
Question LN IMS Bearing - Shoddy Previous Install?
Hey all,
Finally found the time this weekend to drop my 2000 S transmission. As I suspected, I can see a bit of oil on the bottom of the crank where the RMS and crank meet and my clutch fork has zero grease on the two ball sockets which is likely the squeal I hear when operating the clutch at low speeds.
I'm afraid that I've opened a whole new can of worms though - the IMS bearing was replaced in 2021 (~4,000 miles ago) by a reputable indy shop with an LN Engineering bearing. It doesn't appear to be leaking (although it'd be very hard to tell, there was a lot of clutch dust + oil grime buildup around the bottom of the bell housing) but the outermost o-ring doesn't look like it's fully seated. The top left portion is OK, the top right portion is a little loose, and the bottom is completely loose (you can see in the pictures below).
I'm guessing I already know the answer to this, but is this something I need to be concerned about (i.e. replace the IMS while I'm in here, even though it's relatively new in terms of mileage)?
alexpinson5 is offline   Reply With Quote
Old 03-03-2024, 10:23 AM   #2
You may not need to replace the actual IMS bearing, but you may want to contact LN and inquire about getting a replacement flange cover. Replacing just the cover requires prepping the car as though you were going to pull the bearing however (engine locked at TDC, cams locked, etc.).
Old 03-03-2024, 10:29 AM   #3
Thanks, was hoping that was the case over a whole bearing replacement. Further searching shows they sell an o-ring and sealing bolt kit that is pretty inexpensive so I may not even need the flange. I'll reach out to them and see what they say.
Old 03-08-2024, 05:00 AM   #4
Finished up last night. Really took my time, locked the cams, removed the tensioners, all that fun stuff. The bearing seemed to be in great shape (which is what I expected with a relatively low amount of miles on it) so I'm leaving it in.
I was able to get the IMS flange back in without pinching the outer triple-seal like the last installer did. Once my new RMS arrives I can get things buttoned back up and start driving!
Old 03-08-2024, 12:28 PM   #5
Nice work!
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
Tags
ims , ims bearings , rms
