Old 02-10-2024, 08:17 AM   #1
A 986 S's Avatar
clockspring tabs
The turn signal on my Boxster didn't self-cancel when I bought it. The problem was that the ends of the delicate tabs that actuate the self-canceling mechanism had broken off. My fix was to replace the broken clockspring and the attached combination switch with a used clockspring/combination switch that I found on eBay. This has worked just fine for years even though one of the tabs on the replacement was broken when I got it. It's hard for me to understand why Porsche would have designed the part to be so fragile... Anyway, here's a photo to show what I'm taking about.
A few photos from when I did the work here - https://rx19jones.wixsite.com/projectboxster/projectboxster-1
dj
2002 Boxster S Orient Red Metallic / Graphite Gray
https://rx19jones.wixsite.com/a-986-s
A 986 S is online now   Reply With Quote
Old 02-12-2024, 07:48 AM   #2
highsider's Avatar
Thank you! Really helpful advice. I'll take the stalk switch unit out and look to resolve
highsider is offline   Reply With Quote
Old 02-13-2024, 05:16 AM   #3
1998 Boxster Silver/Red
If you're going to remove the switch you might look into the 3-4 stalk setup. Onboard computer access, etc. It's been posted upon the forum many times, and is a nice upgrade. Good luck.
1998 Porsche Boxster
Tags
indicator
