Old 08-26-2023, 09:41 AM   #1
Trick to removing radiator strakes
Is there a trick to pulling these off? Looks like they should come straight out, but it takes more force than I was willing to do at first. Does it help to angle them up or down?
s_wilwerding is offline   Reply With Quote
Old 08-27-2023, 06:22 AM   #2
2003 S, Arctic Silver, M6
paulofto's Avatar
Be careful, the tabs holding them can easily break. The tabs can only be jimmied from behind and to do that you need to remove the bumper. Why do you want to remove them?
Old 08-27-2023, 12:24 PM   #3
Thought it would be easier than taking the bumper off to clean the radiators.
Old 08-27-2023, 01:50 PM   #4
78F350's Avatar
You really need the bumper cover off and separate the AC condenser. Otherwise it's a waste of time.
Old 08-28-2023, 02:45 AM   #5
Registered Member
100% spot on!
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
Old 08-29-2023, 05:12 PM   #6
JBauer's Avatar
There are metal clips on the back. You can't just pull them off from the front. You have to remove the bumper, then remove the clips and the pull right out.
JBauer is online now   Reply With Quote
